Help diagnosing problem on 2000 S4 76k mi
My CEL is on with the following codes:
17544-Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
17546-Long Term Fuel Trim Add.Fuel,Bank2 System too Lean
17521-Bank1-Sensor1 Internal Resistance too High
Searching the archives it seems it could be caused by the following:
Water Temp Sensor
O2 Sensor
MAF
What course of action does Audiworld suggest considering the model and mileage (btw - all parts are the original factory installed)
Clean MAF? (seen DIY instructions on this somewhere)
Replace Water Temp Sensor?
Replace O2 sensor? (any DIY tips?)
Water Temp Sensor
O2 Sensor
MAF
Put a new passenger front O2 sensor in and a new (refurbished MAF) - then call it a day....
You can get both pretty cheap and your codes should go away.
Never heard of a coolant temp sensor throwing those codes.
Yes, 2000 MY uses Bosch MAF
I don't think my version of VAG-COM supports logging. (I am running an old "dumb interface" version because it's such a PITA to upgrade).
