HELP - doing TBA, after hitting GO, get ERROR in right box (more)
Was swapping ECU's. When putting in the "new" one, the larger connector was a little harder to slide the locking bar into final position, and when I ran the TBA I ended up with the ERROR display. Disconnect and re-connect the new ECU, try again, same result. When I check for fault codes, I get some sort of TBA not completed type of error code (sorry - didn't write it down). Does not go away with CLEAR CODES.
Pulled out the ECU, looked at the pins on it and the two connectors. ECU pins are all straight, connectors look OK as best as I can tell.
Put back stock ECU, no fault codes, and guess I should have left well enough alone. But I tried to run a TBA on it, and it too came up with ERROR, and it too now has the same fault code. Driving it with stock ECU, as that was the CPU with the last successful TBA.
Any and all help welcomed! TIA
Good battery strentgh (voltage requirement)
Not too hot
Not too cold (I think)
I'm not sure if there are other requirements or not...
Not too hot
<ul><li><a href="http://www.ross-tech.com/vag-com/cars/throttlebody.html">http://www.ross-tech.com/vag-com/cars/throttlebody.html</a></li></ul>
Mikey'sS4
05-20-2004 03:07 PM
BluTTo
08-01-2001 07:23 PM
