Help on a DTC - is this a "broken" MAF?
Old 08-04-2006, 06:28 AM
Junior Member
pattersom's Avatar
Default Help on a DTC - is this a "broken" MAF?
16486 - Mass Air Flow Sensor (G70): Signal too Low
Background is my MAF popped off the air box and I ran around for 2 days before I figured it out. I hooked it back up and reset the codes. But it immediately came back.
Did driving around with out filered air destroy the MAF?
BTW, the code when the MAF was popped off was the same.
Old 08-04-2006, 06:30 AM
lemieux@curbside's Avatar
Default 2000 s4 = bosch maf.. disconnect (electrical part) and see how it runs
you might have a bad maf.
Old 08-04-2006, 06:50 AM
nadrealista's Avatar
take it out and wash it in 100% alchohol. it is toast if code comes back after that
Old 08-04-2006, 09:10 AM
Junior Member
pattersom's Avatar
Default I've had slowly failing MAF's...
I've replaced at least two - this one has lasted the longest.
I recall the codes were fuel issues as opposed to simple low readings. That's why I wonder if the failure mechanism is different - i.e. damage as opposed to slow wear out.
pentosinjunky
03-30-2008 04:51 PM
petewon
07-16-2006 03:41 AM
wonder1and
08-04-2004 01:51 PM
Michael Benno
08-29-2003 07:31 AM
Quick Reply: Help on a DTC - is this a "broken" MAF?
