Help with DTC's...
Here is what I saw from the VAG-COM tool:
16490 - Manifold Pressure Sensor (G71/F96): Implausible Signal
35-10 --- Intermittent
17973 - Throttle Body Controller (J338): Lower Stop not Reached
17987 - Throttle Body Controller (J338): Adaptation Not Started
16622 - Manifold Pressure Sensor (G31): Signal too High
16497 - Intake Air Temp. Sensor (G42): Signal too High
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
18010 - Power Supply Terminal 30: Voltage too Low
The ones concerning the Throttle Body Controller were probably caused by failed adaptation attempts. The 18010 was probably caused when I swapped ECU's. Should I be worried about the others?
Dealer replaced an engine coolant sensor in about 10 mins - about the size of a golf ball and goes at the rear of the engine. Actually, maybe he just put a golf ball in there, but the code went away nonetheless.
Suggest you call the dealer and say you have a check engine light of three - that way they may take you straight away rather than making you wait 2 months for an appointmtnt.
