HELP......Have DTC code. what does it mean.
I VAG at home and this is the reading
17950 Throttle Actuation
implausible signal
35-10 intermittent
Am I in deep trouble. Please advise, what I should do.
implausible signal
35-10 intermittent
Bentleys says to:
"Check angle sensor for throttle drive"
- First try a TBA, see if that fixes it.
If not:
- Go to measuring block 62 in the engine module.
Do the following:
- Observe display fields 1 and 2. Slowly depress accelerator pedal to full throttle position.
The percentage value in display field 1 should rise steadily, but without covering the full tolerance range between 3 - 93 %. The percentage value in display field 2 should also rise steadily but without covering the full range of values (in this case 4 - 49 %).
If the display values do not appear as described:
- Check voltage supply and wiring to accelerator position senders.
- Observe harness connectors for the following: Loose connectors, not properly engaged or corroded.
Still got problems:
- Check accelerator position sensors
If the TBA didnt fix it for me it would be dealer time. :-/
- John
2000 Santorin S4
MTM Stage II
Tanoga SS
Euros
710N's
If not:
Do the following:
Still got problems:
- John
2000 Santorin S4
MTM Stage II
Tanoga SS
Euros
710N's
ricekikr
10-29-2010 05:23 AM
djtalon
05-28-2003 06:56 PM
SeeYa4
12-23-2002 05:17 PM
Simkin
06-19-2002 06:13 AM
