HELP! How can I eliminate check engine light permanently without VAGCOM?...>>>
have a misfire that will not go away and I don't want to see the check engine light anymore... should I remove a bulb or fuse or something? For those who think this is a bad idea I will still check my codes periodically to see if there is anything wrong.
TIA.
TIA.
the key in accessory mode.
Fix the problem. Ignoring it could potentially cause serious future damage.
