Help.. I accidently ran leaded gas!
Hello everyone,
I've been getting alot of help over at audizine but I figured I'd ask here as well. I accidently ran a 50/50 mixture of leaded gas yesterday thinking it was unleaded performance fuel. Now my 02 sensors keep throwing up an error code. (I've had it cleared and it relit) Can I pull this one over on the dealer or will they know what happened immediately? Infact would they void my whole warranty for running improper fuel?
thanks in advance,
Jon
thanks in advance,
Jon
think if that happened you would feel a loss of performance. Those are the only parts that should be effected.
Pretty sure the cats won't like the lead though and will need replacment. I'd give it two or three tankfulls and see. It may also be a good idea to drain the gastank.
There's definately been a loss of performance.. It turned from a banshee last night into pretty much stock like performance..
Jon
Jon
be enough to hurt anything. I know when I had an Eclipse the DSM guys ran race gas (w/o a cat) all the time and it took a long time for it to hurt the O2 sensors. Maybe the Audi units are not as tough.
In my stupid day thinking that aircraft low lead was okay to use, I ran it quite often with no issues in my obd2 car.. Don't run that **** in your car though, it's worse then normal leaded gasoline
