HELP........i think that there is something wrong with my car
my my gas pedal or car has become very sensitive. you know how the first gear is super sensitive; you give barely any gas and it jerks forward; you let go of the gas and it jerks again. well i just noticed that all the rest of my gears are doing the same thing. it's not that noticeble with the higher gears, however, it still does it. second gear is the most obvious. at around 1500 to 20000 rpm, it very sensetive. if you're driving normally, barely giving gas and let go, it jerks back. then, if you give it barely any gas, just put your foot on it, it jerks forward right away. it used to be smooth; you let go of the gas and it slows down smoothly without the jerk, and if you press the gas again litely it start to move forward smoothly. however, now there is this initial sudden jerk every time i press the gas. also if you press the gas all the way down, it first jerks then starts to pull a little less and then the turbo kicks in and it starts to pull again. i just put on a neuspeed g2 exhaust on it. could it have caused that, or am i just paranoid. if anyone know what it could possible be, please let me know
Check all the mounts on the G2 to make sure it's not hitting anything.
The jerkiness from on-->off throttle is normal to a certain extent, but you might want to have your motor mounts checked.
GDawgA4
09-29-2005 04:59 PM
MikedaPimp
02-04-2001 05:43 PM
