Help me diagnose a problem with my turn signals.
Old 10-07-2004, 07:11 AM
  #21
dscottjr's Avatar
that trim surround just pries off.
Old 10-07-2004, 07:13 AM
  #22
Senior Member
Nick Gustas's Avatar
I used an expired credit card and a hotel key card. It comes off towards the front IIRC.
Old 10-07-2004, 07:14 AM
  #23
dscottjr's Avatar
yep.
Old 10-07-2004, 07:47 AM
  #24
AudiWorld Expert
Mark P's Avatar
Default yeah, I use a tiny flathead to help pry towards the rear of the car until I can get my fingers
in there to grab it and pull it more. Be sure to pull it straight back, and maybe work from one side to the other. THere are 6 metal tabs holding it on, and don't be surprised if one of them breaks off - it will still go back on just fine.
<img src="http://ctny.audiworld.com/mark/s4/other/cupholder/mvc515f.jpg">
After getting that out of the way, the fun begins. Ok, it's not that bad...
You'll see 4 tabs to remove at the top of the fog buttons and cupholder:
<img src="http://ctny.audiworld.com/mark/s4/boostgauge/dsc01458.jpg">
Do that and open up those holes cuz you'll need to get your fingers in there.
Now, along each side of the hazard swich there is a metal band that flexes out at the front side. When installing, when you push the switch into place, these bands/clips extend outwards, locking it into place.
I've found the best way to get this part out, is to take a small flathead again and push on one of those bands, let's say the right one. As you are pushing on that, you are going to unclip the right side of the switch. With your left hand, reach into the foglight button hole and push the rear of the hazard switch to the right, so the front right of the switch pops outwards. Now put down the screwdriver while still applying pressure with your left hand. Insert your right hand into the cupholder hole and reach as far back as you can, and now with both hands, keep enough pressure to keep the right side unclipped, and push/pull the unit towards you. THis pressure will allow the left clip to come undone as well and you're all set.
Good luck
Old 10-07-2004, 08:17 AM
  #25
Rest In Peace
O.W. Kenobi's Avatar
Perfect. Thanks!
Old 10-07-2004, 08:21 AM
  #26
Stätus Josh
Guest
Posts: n/a
Default Maybe you are low on turn signal fluid?
Seriously though, you just need to replace the Hazard button (the relay is built in). I had a customer experience the same thing and this fixed it immediately.
Old 10-07-2004, 08:23 AM
  #27
Rest In Peace
Default Unpossible. I just flushed with synthetic.
I STFA'd, and read that the Kale Co. stuff is used in all the race cars.
;-)<ul><li><a href="http://www.kalecoauto.com/fluids.htm">http://www.kalecoauto.com/fluids.htm</a</li></ul>
Old 10-07-2004, 08:25 AM
  #28
Dr. Jekyll's Avatar
Sounds like its time to change your blinker fluid :-P
Old 10-07-2004, 08:26 AM
  #29
Dr. Jekyll's Avatar
damn it, you beat me too :-)
Old 10-07-2004, 08:34 AM
  #30
RKA
AudiWorld Uber User
RKA's Avatar
...and tons of A4 owners have already had this issue.
Quick Reply: Help me diagnose a problem with my turn signals.
