Help me diagnose a starting problem, Part IV: I've narrowed it down to battery, alternator, or start
er...
The symptoms:
Car would only fail to start when the engine was hot.
Absolutely no problems when engine was cold, even when left outside overnight in the winter.
My question: Why would a hot engine cause any of these items to temporarily fail, and which of these items is it likely to be?
The reason I've narrowed it down to these 3 items, BTW, is that today my car failed to start completely after I had shut it down earlier.
Usually, it would fail to start for ~ 15 minutes, and then I could start it up again.
After trickle-charging it for a few hours, however, I was able to start it back up again.
The only DTC I have is a low-voltage battery code, but as I understand it, that doesn't necessarily rule out the starter or alternator...
TIA.
The symptoms:
TIA.
do you hear the starter attempt to engage or is there just a clicking sound or a grinding sound when you try. This sounds like a typical starter problem. If it was the alternator the battery would be totally dead, and you couldnt start it. If it was the battery, same thing. So that would leave your starter.
Here's the reason I ask: I had an alternator, and so did one other person on here, that didn't have any problems charging when cold. If you tested it on a tester for 2 hours, it wouldn't matter.
As soon as it rode in the car for 30 minutes, bam! Low voltage.
TwinTurboTerror
Mid Atlantic Discussion
19
08-25-2006 12:22 PM
escapA8
10-25-2002 07:39 PM
