HELP!!!!!! My S4 is only running 5psi??????
Hello All,
My 00' S4 is now only running 5psi with a MTM ECU and a stock ECU, it is slow!!!!!
Does anyone now what would cause this????
Could this be attributed to bad Diverter Valves??? Can this be checked with the VAG-COM??
If anyone can give me some info on why this is happening, I would appreciate it very much.
check with VAG tool if you can. If you get 17965 or 17535, chances are your F-hose or TBB is ruptured. That was what happened to me...
you may be able to feel the split. If you see oil residue on the F-hose or around the area, your F-hose is ruptured. You need to remove the BPV to replace it though.
I checked the F-hose and it is in perfect shape, so I guess I will have to check it with the VAG.
swinmachine
03-05-2004 12:45 PM
DAP@EPL
15
09-18-2003 01:19 PM
S4Del
08-20-2002 06:58 AM
TRM
10
04-01-2002 07:17 AM
