help , OEM Rs4 exhaust.
hello
I can install oen RS4 exhaust on s4, or 2.8q avant.
this is new, all for 200$ with cat, I want it to drain the catalyst and to have original and the cat-back.
thanks.
thanks.
AudiWorld Expert
experience. I would imagine since it's the same (within reason) body with the same engine, and also since the RS4 turbos fit into the S4's plumbing, that yes, the RS4 exhaust would fit on an S4. But I don't know that for sure
AudiWorld Expert
Translation is after the ">"....
hello
>hello
> can I install and OEM RS4 exhaust on an S4 or onto a 2.8q avant?
> This is a new exhaust, that I got for only $200. I want to remove the cats from the RS4 exhaust, thus using the original S4 cats and the RS4 cat-back.
thanks.
>thanks
heehee. Well, that 2nd portion could be not quite right, but it seems reasonable
hello
>hello
thanks.
>thanks
AudiWorld Expert
Since people have been putting RS4 turbos in S4s, the connection between the turbo and the exhaust (downpipes/cats) is the same on both cars. However, you mentioned maybe using the S4 cats/downpipes and then the RS4 cat-back exhaust section. Well, I'm not so sure if that sectionconnection-point is the same. It may be thicker on the RS4, or even completely different. Just some thoughts.
Also, I belive some people have put S4 exhausts onto A4 2.8's, but they needed to modify part of it. I would have to imagine that the RS4 exhaust would have a much easier time fitting onto the S4, than the A4 2.8.
good luck, and let us know how it turns out
