HELP! one of my SSR Comp wheels is stuck at the hub and can't remove the wheel, any suggestions?
...I mean "mallet"!
Thanks!
THIS...
<img src="http://www.wolverinesports.com/WOLV/TR351P.JPG">
The dang hub!
<img src="http://pictureposter.audiworld.com/15588/dscn0404.jpg">
..and the dang SSR hub ring!
<img src="http://pictureposter.audiworld.com/15588/dscn0405.jpg">
finally came off...whew!
BTW, My SSR Competition 18X8.5 with Bridgestone 235/40/18 S03 Pole Position (about 6K miles on them) is FOR SALE! $1,900 OBO email me please.
<img src="http://pictureposter.audiworld.com/15588/ssr_comps_2.jpg">
THIS...
The dang hub!
loosen but don't remove lugs, then drive slooowly and slam on brakes, or lift the car slightly off the ground, then lower it back down.
Turns out that the hubcentric ring wasn't exactly "flat". That is, one end was seated in a little further inside the wheel than the other. What a nightmare.
It took me an hour to get it off.
If you notice, one end of the wheel will rock back and forth. Being gentle did not do the trick for me. So I just hit the backside of the wheel with a rubber mallet and then yanked the wheel off as hard as I could.
What a PITA. That hubcentric ring is fairly tight. I would promptly take a dremel to the hubcentric ring and take away just a hair of some material on the outside circumference and the inside so the hubcentric ring slides in and out of the wheel.
take all the lug bolts out but leave one in. Loosen the last one but dont take it all the way out. Then from the back side tap the tire only with a dead blow hammer or a rubber mallet. The lug bolt will keep the rim from falling off the car and scraping it.
