Help! Repl. B2S2 w/ spare VW Passat (ABA) Bosch secondary O2, no success. Which four-wire O2 to use?
My B2S2 O2 sensor went dead (open circuit) so I set out to replace it. I had a brand new four-wire Bosch O2 sensor (for a VW Passat/Audi A4 1.8T ABA) sitting around and I decided to splice it in to the existing wiring.
Polarity of the two heating element wires was verified with a wiring diagram from Elsa. I used top-quality Wurth heat-shrink butt connectors to do the job.
The car is now throwing a different O2 sensor code:
<pre>17518 - Oxygen (Lambda) Sensor Heating: B2 S2: Heating Circuit Short to Plus</pre>
I measure the resistance across the heating element circuit in my replacement sensor at 5 ohms. The existing, good O2 sensors are all at 10 ohms.
Before I go out an buy another cheap four-wire VW Bosch sensor, is there anything else I should try?
What is the most commonly used VW (or less-expensive, but identical) O2 used for secondaries on these cars? Part no.?
p.s. Pic for views.
<img src="http://pictureposter.audiworld.com/114290/s4_i3z9901-1.jpg">
p.s. Pic for views.
short to power... check your connection. Also i would stick to solder then cover with heat shrink.
Log your o2's and see what they are doing there is a slim chance they will be doing their job.
quattro_blue
02-05-2008 09:00 PM
Gator Al (Al)
18
05-10-2004 09:09 PM
maxma
01-31-2003 07:21 AM
Jeremy Clarkson
09-25-2002 07:04 AM
