help..... what would cause the ecu to cut the boost.
<center><img src="http://pictureposter.audiworld.com/14833/dscn0468.jpg"></center><p>something wierd just happened. drove the car and it was making no boost like 5 pounds, i run an abt/ams chip and i have a boost gauge so i was able to see the boost. i came home and did an adaptation hoping this would reset the ecu, with the key and the boost returned, although i thaught i heard some vacume leak, then the ecu shut the boost down automatically again. i cant hear any hissing unles the car is under load and every time i test to hear where it is coming from the ecu kills the boost and has to be reset. what would cause the ecu to cut the boost. is there a spacific hose that if blown would do this? my tbb boot looks fine and does not seem to be hissing and i have no ce light on. any help would be realy appreciated.
If you remove the ECU, let it sit for a bit, reconnect, you'll be fine for say a couple of miles, than CEL comes on again, causing it to go into limp mode. If you have a 2000, must be teh BOSCH, mine was replaced today, running happily 16 PSI again....
