Helping my friend cleanup a KTR Diaster!
VAG-COM Version: Release 404.0-S
Control Module Part Number: 8D0 907 551 M
Component and/or Version: 2.7l V6/5VT G 0002
Software Coding: 06711
Work Shop Code: WSC 14136
9 Faults Found:
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
17938 - Camshshaft Timing Adjustment: Short to Ground
P1530 - 35-00 - -
17955 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-00 - -
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 35-00 - -
17529 - Oxygen (Lambda) Sensor Heating Circuit: B2 S2: Short to Ground
P1121 - 35-00 - -
17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-00 - -
17865 - Exhaust Gas Temp Sensor 2 (G236): Open or Short to Plus
P1457 - 35-00 - -
Heres the story, KTR installed the turbos forgot to put the grounding nut on fried ALL the electronics in the car! So now that the ECU / ABS ECU has been replaced now we have to replace the remaining sensors that are fried.
The code above, looking at the car is it the one on the left or right?
9 Faults Found:
P1425 - 35-00 - -
P1530 - 35-00 - -
P1547 - 35-00 - -
P1289 - 35-00 - -
P1121 - 35-00 - -
P1117 - 35-00 - -
P0102 - 35-00 - -
P1453 - 35-00 - -
P1457 - 35-00 - -
Sounds like maybe - i met a guy (forget his name) this winter with hybrids that had this problem.
He was having Craig (Toy Guy) install a short shifter in the parking lot of my office building.
I have a hard time thinking this happened to two people, but who knows?
