Here it is! My write up on my Aquamist 2d install / experience / results... (long & BWW)
#13
Some things to log might be the knock voltages. Since the wi benefits aren't only related to intake temps you may see quite a change there. Next you can add timing and/or lean the fuel out a bit. You won't need the over-rich conditions to suppress knock quite as much now. Of course your FATS times for these changes will be the deciding factor.
Wow. That writeup is just impressive.
#17
Glad you like the system, I'm going to try out another pump, as I killed the aquamist pump. This new one can take pure methanol and flows 220 psi vs. the Aquamist pump's 100psi. (Yes, I know, I'm talking pressure, not flow, but I just got back from 2 days at the Glen and I'm beat.)
Since you're using 2 0.8mm's, see if you have room for 2 accumulators. Or you can go nuts, put a 5 gallon fuel cell in the trunk, use a big SupraTT pump and -6 lines to the engine bay...but that may be a BIT overkill. :-)
#18
AudiWorld Expert
again, it wasn't that any one thing took very long, we just took our time to plan out everything, etc.
Thanks again for all of the help - it was really appreciated!
