hey i need some help w/ some fault codes
lately i've been getting bad shudder when coming off the gas and i assumed i was just in need of some new motor/tranny mounts, but then i threw a check engine light last week and that got me thinking. i searched the archives and i was thinking it's probably a bag EGT sensor, and then today the car went into limp mode so that basically sealed the deal. i just ran out to the car and these are the codes i threw:
Address 01: Engine
Part No: 8D0 907 551 B
Component: 2.7l V6/5VT G01 0003
Coding: 06651
Shop #: WSC 40821
7 Faults Found:
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17861 - Exhaust Gas Temp Sensor 1 (G235): Open or Short to Plus
P1453 - 35-00 - -
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-00 - -
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
Readiness: 0010 0001
From what i can tell, the positive boost deviation means my boost spiked too high? how can the car tell that if I have a TCD? the EGT fault means my EGT sensor is shot right? is sensor #1 on the driver or passenger side bank? what do the other O2 sensor faults mean?
Address 01: Engine
Coding: 06651
Shop #: WSC 40821
7 Faults Found:
P1453 - 35-00 - -
P1118 - 35-00 - -
P1114 - 35-00 - -
P0140 - 35-00 - -
I need to pass my emissions in CA and this is the first step in the costly exercise.
i would try carlson first and see the price.
its about $220 or so per side.
germanautoparts.com
www.autohausaz.com
if you can get it for less than $170 is a very good deal.
germanautoparts.com
www.autohausaz.com
valentine1
11-13-2009 06:09 AM
Edd W
04-02-2009 02:52 AM
Edd W
04-01-2009 03:21 PM
vitoal18t
10-01-2006 02:44 PM
