Hi guys... really need someone to help me... My friend is going to give his RS4 full stock exhaust
system to me(including DP, Cat/back exhaust. I really need someone to tell me whether or not the RS4 Full exhaust fit my S4. Please give me some detail information like.... if not fit, which part is the problem.... or if only the DP fit, can I order S4 after market back exhaust to get them install together? with which Tuner's exhaust? Many Thanks.....
if you do a S4 aftermarket cat-back, you'll need to extend one of the RS4 DPs to meet the new exhaust (no big deal, but worth it)
Miltek if a good choice for a smooth/quiet exhaust
Are they the silver short pipes that I can see from the rear bumper? If that's what you refer to, how to change the tips? cut the RS4's down and put something on? Is it the shape of the rear bumper that limit the RS4 tips?
By the way, are you sure about all this. I must say sorry for asking you this again. I have to make sure this RS4 fitment issue before the Engine is dropped, I don't want to put S4 stock back again if something goes wrong...
Thank you very much
Thank you very much
it is the shape of the rear bumper that limit the RS4 tips which are about 1.5 inches wider than S4 tips.
Look here
<img src="https://www.audiworld.com/model/rs4/gallery/pressphotos/RS4990003.jpg">
I am very confident on this, but If you are installing the RS4 DPs and the RS4 cat-back doesn't fit, I'd suggest just putting the stock cat-back on for now, and getting an aftermarket S4 exhaust later on.
Look here
Do you mean that I can use RS4 DP and link to Stock S4 back exhaust without any mod? How about the extention pipe between RS4 DP and after market back Exhaust you mentioned before?
of the system (after the cat) to the stocker (or aftermarket S4 cat-back.
just make sure your mechanic is prepared (with materials) to make the modification. It's not hard...it just needs to be welded.
STEALTH_6
07-20-2007 05:50 PM
Audi_in_Van
9
04-06-2007 09:49 AM
reefer_bob
04-30-2005 04:17 PM
