HID light was flickering extremely fast. whats up with that?
is it the bulb? most likely the ballast, right?
this happened after they were on for about 2 hours. parked overnight, then it was gone the next morning.
Most likely the ballast. If you want to be sure, swap the ballasts on your headlights and see if the problem follows the ballast, or the headlight assembly. You will need a Torx 20 bit to get the headlamps out, and a Torx "security" (ie. with a hole drilled in the middle) bit to get the ballasts out.
Theoreticaly, it could also be the headlamp starter or a flaky electrical connection, but the ballast would be the highest probability. I recently had to replace my ballast, and I had to beg the Stealership for a discount. The original list price was over $600, but I haggled them down to a mere $510. Such a deal. I have an early build car, so I couldn't find one that I was sure would work on E-bay.
btw if it is ballast..just buy whole headlight form junkyard(car-parts.com)..I got mine for 250...just swapped the whole headlight..
skimvic13
12-16-2008 08:53 AM
üBER.QIK
08-31-2007 08:08 AM
absoluTT A3
07-25-2007 09:55 AM
larrs8
09-10-2004 12:14 PM
