homebrew water injection - pump and pressure regulator idea
Here's the pump and pressure regulator I have in mind. The regulators are on ebay ~$110 new, and the pumps run around $60-75 new. After this, I still need nozzles, solenoid valve, and boost switch to control the valve. I'll probably try bidding on used ones, if reefer_bob isn't logged on.
Spray.com has nozzles with built in mesh screens, but I haven't picked one yet. Then again, it would be easier to use aquamist's nozzles.
Another idea is, since the pump has so much extra flow, I could install an extra tee and solenoid valve to spray nozzles on the ICs. That way I could run the water injection with or without the IC sprayers to save on water.
I called aeromotive to ask if their regulator would handle water without rusting. He said it should be no problem since it's aluminum and the seat is plated steel.
What pressure does aquamist use for their nozzles? I'm sure I can find it online but does anyone know? I planned on using 40psi, raising to 60 with boost.
The problem with most cheap WI kits is they don't factor in the fact that a nozzle will flow less as boost rises. You would have to size the nozzle for max boost. Any other time the nozzle will flow too much water. By setting up a loop, with the regulator, it will maintain proper pressure, just like fuel injection.
This way I can use the cheap shurflo pump.. Not to mention save quite a few hundred over buying aquamist. Has anyone priced out a replacement aquamist pump?
<a href="http://www.shurflo.com/pages/new_industrial/Industrial/gen_industrial/subcategories/8000_ADP_12DVC.html">shurflo pump</a>
<a href="http://www.shurflo.com/pages/new_industrial/Industrial/gen_industrial/genind_doc_sum/8000-543-238.html">shurflo pump pn 8000-543-238</a>
<img src="http://www.shurflo.com/pages/new_industrial/Industrial/gen_industrial/genind_img_sum/8000-Series.jpg">
<img src="http://www.aeromotiveinc.com/prod_imgs/img-10-1-large.jpg">
<a href="http://www.aeromotiveinc.com/pdetail.php?prod=10">aeromotive regulator</a>
if the pump is pushing 60 psi into 20 psi of boost, the result is effectively 40 psi of water pressure. Make sure that's enough pressure to adequately atomize the water, the finer the water droplets the more effective the WI system will be. If the droplets are too large they won't absorb as much heat, and will have more trouble staying suspended as the airflow changes direction.
and there's also a 220psi upgrade pump. BTW, are you planning to go 1 or 2 nozzles and where would you be placing the nozzle(s), near the throttle or further back? 8^)
I'll look into it. It definitely makes sense to use higher pressure for smaller droplet size. IF so, shurflow does sell a 150psi pump similar to the other one.
I assumed you would get way more than 200cc/min (0.052 GPM) out of a 0.7mm (0.027") dia spray nozzle at much more than 40 psi. A typical spray.com nozzle with 0.025" dia, shows getting 1135 cc/min at 100 psi. The aquamist nozzle must not have a smooth hole. Of course, sray.com has hundreds of various nozzles, so I'll look into it further. thanks for the help
The kit has what looks to be a shurflo pump. The problem is I don't see where all the extra water goes. They must be using a pump with an internal bypass. It runs up to whatever pressure it's set at which opens the internal bypass valve.
With a separate regulator, I could adjust the pressure to fine tune the flowrate of the nozzles. WIth the boost connected to the regulator, it would maintain the same flowrate as boost raises.
Active
EVO Specific: No
Capabilities: Adjustable manifold pressure activation
Pump: Shurflo
Electronic Controller option:: not mentioned on site
Chemical compatibility: Water, Alcohol
Failsafe: not mentioned on site
Price range: US$750.00
Warranty: Not mentioned on site
URL: http://activeautowerke.com/cooling/main.php
EMAIL: aatuning@activeautowerke.com
Alkycontrol
EVO Specific:
Capabilities: Progressive delivery proportional to MAP sensor
Pump: Shurflo
Electronic Controller::Based on PAC module controlling pump speed to vary pressure
Failsafe: low alcohol sensor
Price range: US$425-495
URL: http://www.alkycontrol.com/
EMAIL: Online form or phone 727-526-9724
Aquamist
EVO Specific:- NO
Capabilities: Static flow, mappable, ECU interface and map switching
Pump: Own design - magnetic piston type
Chemical compatibility: Water, Methanol. (100% methanol and 10-20% nitromethane (teflon seals -supply on request)
Failsafe: - Dash Flowmeter or full-time monitoring via "signal error comparator" circuitry - boost control and map switching output.
Price range: US$585.00-3000.00+
Warranty: 12 months
URL: www.aquamist.co.uk
EMAIL: info@.aquamist.co.uk (sales enquiry), richard@aquamist.co.uk (technical)
Aquastealth
EVO Specific:
Capabilities: Static flow, Pressure switch activated inline solenoid.
Pump: Shurflo
Chemical compatibility: Water, Methanol, isopropyl and ethanol.
Failsafe: unspecified
Price range: US$239.00
URL: www.aquastealth.com
EMAIL: sales@aquastealth.com
Coolingmist
EVO Specific:
Capabilities: Static flow - single or duel solenoid
Electronic Controller: Micro-based pump pressure/speed controller. Price to be announced.
Pump: Shurflo
Chemical compatibility: Water, Methanol safe
Failsafe: hi/lo system pressure switch to detect loss of pressure or clogged jet.
Price range: US$199.00-499.00
Warranty: 90 Days
URL: www.coolingmist.com
EMAIL: sales@coolingmist.com
Devilsown
EVO Specific:
Capabilities: Static flow, PWM pump speed control option
Electronic controller option: 2/3 bar option - pump speed control . Price US$105.00
Pump: Shurflo
Failsafe: Pump current overload detection. update
Price range: US$185.00-345.00 + MAP sensor
Warranty: One Year Limited
URL: www.devilsownonline.com
EngineRunup
EVO Specific:
Capabilities: Static flow and two stage. Solenoid controlled
Electronic Controller: Call
Pump: Shurflo
Failsafe: two pressure switches to detect clogged jet (250psi) and low tank level option
Price range: US$189.00-359.00
Warranty: 12 Months
URL: www.enginerunup.com
EMAIL:info@enginerunup.com
Gaseous Intercooling TM
EVO Specific:
Pump: Flojet
Failsafe: Flow switch
Price range: $395.00-540.00 basic to Standard Plus (with solenoid)
Electronic flow controller: US$195.00 sold as an optional extra
Warranty: 90 Days
URL: http://www.blowerworks.net
EMAIL: greg@blowerworks.net
Hyper-drive
EVO Specific: YES
Capabilities: Mappable pump speed controller
Pump: Shurflo
Failsafe: low water level sensor.
Warranty: not mentioned on site
URL: http://www.hyp-drive.com/products/alcoholinj.htm
EMAIL: resolution@hyp-drive.com
RSR
EVO Specific:
Capabilities: Static flow, Port injection
Pump: Shurflo
Failsafe: water level switch
Warranty: call
URL: www.rbracing-rsr.com/waterinjection.html
SMC
EVO Specific: YES
Capabilities:Progressive controller
Electronics controller option: - control pump speed to vary flow.
Pump: Flojet/Rotary fuel pump
Failsafe: tank level sensor at present.
Price range: US$399.00-499.00
Warranty:90 Days
URL: www.smcenterprises.com
EMAIL:schlupsa31@mchsi.com
Snow Performance
EVO Specific: YES
Capabilities: Static flow, solenoid
Electronic controller option: Progressive pump speed controller +$129.00
Pump: Shurflo
Failsafe: flow switch based. $99.00
Price range: US$185.00-439.00 (MAF vs Pump speed)
Warranty: limited option by vendor
URL: http://snowperformance.net
EMAIL: mbsnow57@msn.com
Spearco Water Injection System
Location: Top-End Performance, N.Hollywood, California.USA.
EVO Specific: No
Pump: Not specified
Failsafe: Not secified
Price range: US$219.00
Warranty: Call
URL: http://www.h2oinjection.com
EMAIL: topend@racetep.com
TTP Engineering
EVO Specific:
Capabilities: Static flow, Progressive controller -sold separately(PWM pump)
Pump: Shurflo Based
Control option: pressure switch, TPS or MAP (0-5v selectable)
Failsafe:upgrade path available
Price range: from US$299.00(base) + accessories
Electronic Controller: Variable injection rate controller now available
Warranty: Call
URL: http://www.ttp-engineering.com
EMAIL: online form filling
EVO Specific: No
Pump: Shurflo
Alkycontrol
EVO Specific:
Pump: Shurflo
Aquamist
EVO Specific:- NO
Warranty: 12 months
Aquastealth
EVO Specific:
Pump: Shurflo
Coolingmist
EVO Specific:
Pump: Shurflo
Warranty: 90 Days
Devilsown
EVO Specific:
Pump: Shurflo
EngineRunup
EVO Specific:
Pump: Shurflo
Warranty: 12 Months
EVO Specific:
Pump: Flojet
Warranty: 90 Days
Hyper-drive
EVO Specific: YES
Pump: Shurflo
RSR
EVO Specific:
Pump: Shurflo
Warranty: call
SMC
EVO Specific: YES
Warranty:90 Days
Snow Performance
EVO Specific: YES
Pump: Shurflo
EVO Specific: No
Pump: Not specified
Warranty: Call
TTP Engineering
EVO Specific:
Pump: Shurflo Based
Warranty: Call
so you can adjust how much water you want at any given pressure as long as it's scaled say from 1psi to 15psi. Between the regulator on the pump, the electronic boost pressure regulator, and the jet size, how much more regulation can you ask for?? You must work for the IRS?? =) I did however have an idea of using a greddy emanage as a controller for total output control over everything using any other system as a referance. Maf voltage, boost pressure, injector duty cycle. Absolute total control of pressure any where in the rpm band. Would love to see someone give it a shot one of these days.
