Hotchkis sway bars any good? im reading that the back is 22mm.. that seems much thicker then stock.
understeer. Seems that a hollow A4 front sway is better. I'm running the Neuspeed 19mm on the soft setting and find it fine. Switching to an Intrax rear sway in the Spring once I get a hold of some coilovers.
The front bar is much lighter than stock as well. You don't really need the front bar but it is worth having. Nothing a stasis high bias center diff couldn't take care of =)
Nobody following me has ever commented on it, but I suppose that's a valid concern going forward, given that I'm considering the 4:1 differential at some point.
I have a Neuspeed 19mm rear bar that I set on firm for the track, and I'm running STaSIS (Koni) Motorsports with 700f/800r springs that I usually dial up to the firmest settings at the track.
you are saying that less travel will likely eliminate that problem? It looks like your A4 in that picture is pretty far compressed on the driver's side - is that stock suspension or soft springs? I don't think mine leans that far over, even on tight corners, but I haven't yet run true R compounds...
I pulled off my 19mm swaybar right after I got home from my 600/700 tracksport install.
I could pull the rear wheel up at will on a cloverleaf. Tap in a quick bit of pointless steering input midturn, or just go fast enough, and it'd come up enough to lose grip in terms of being able to accelerate, or I could even feel it through the seat. Didn't like the loss of power exiting a turn, or the excessive oversteer for the street.
going to come up. Just a matter of grip and load. Perhaps the koni motorsports have more shock travel, but with the 19mm on stiff and short travel of 800lb springs, it should still be possible... YMMV!
