Hotchkis sway bars any good? im reading that the back is 22mm.. that seems much thicker then stock.
Old 12-26-2005, 01:47 PM
  #11
OCA::DIY Motorsports's Avatar
Default So far I like mine. I have center diff too which cured most understeer.
I've backed off the damping so in hard corners I've got a bit of bounce since I switched back to lighter springs. I have not put the front bar on...guess I should.
Old 12-26-2005, 02:13 PM
  #12
Senior Member
rojodosformula::red's Avatar
Default I get rear wheel lift pretty frequently with the Teins set all the way stiff.....
Adjusting them down takes care of the problem. The car seems to handle much better set softer as well.
Old 12-26-2005, 03:17 PM
  #13
Senior Member
Nick Gustas's Avatar
Default Engine rpm blipping up is one sign, other times you can hear or feel the tire smacking back down on
the pavement or feel/hear the suspension on that corner taking the loading and unloading.
I dunno, it was pretty obvious to me, swapping back to the stock sway eliminated it for most anything but a harsh parking lot entrance.
Old 12-26-2005, 06:30 PM
  #14
s4gonebabygone's Avatar
Default interesting work... i have the same problem in my s4 on the same tires as you
i'm on h&r ultras and h-sport swaybars. setting the rear swaybar on soft doesnt help either. LSD was my intended solution, but it looks like the car might be replaced now, so i'm not putting any effort into it at the moment. good luck with the radical suspension changes. cant wait to hear how it turns out!
Old 12-26-2005, 08:27 PM
  #15
New Member
beemdubya's Avatar
I have koni coilovers.. the h-sports seem to be reasonable i guess ill try them out.
Old 12-27-2005, 05:12 AM
  #16
Rest In Peace
O.W. Kenobi's Avatar
Interesting. I ran the same tires this season. No autox, though.
Old 12-27-2005, 07:33 AM
  #17
Rest In Peace
225/45/17, on 17x8 wheels. 33f/31r cold pressures. STaSIS aggressive street alignment settings.
Old 12-27-2005, 07:39 AM
  #18
Pat-SoCal's Avatar
Default Hey now :P
Don't go spending too much time and money reinventing the wheel.
nogaro*blue*you*away
17
08-20-2006 05:50 PM
BiturboBoy_V2.0_S3--
16
11-12-2004 11:05 PM
Justin517
03-16-2004 12:40 PM
Ming 2.7T
07-13-2003 12:44 PM
Scott Evil
07-05-2001 06:52 PM
Quick Reply: Hotchkis sway bars any good? im reading that the back is 22mm.. that seems much thicker then stock.
