How can I fix this Coilpack wire?
I started up the car the other day, and the engine was slightly rough/shaky, as if one of coilpacks had died. I measured blocks 015 and 016, and found that Cylinder 5 was constantly misfiring. As far as I can tell, Cylinder 5 is the rear most, on the driver's side. I went to replace the coilpack, and as I removed the Coolant tank I found this on the wires going to (assuming I've identified it correctly) Cylinder 5:
<img src="http://pictureposter.audiworld.com/111844/1205072213.jpg">
<img src="http://pictureposter.audiworld.com/111844/1205072213a.jpg">
The insulation on at least 2 of the wires have been worn through. I didn't proceed to replace the Coilpack, in case this short might cause a replacement unit to fail also.
Suggestions please!
Suggestions please!
I'm going off of the smaller graphic at the bottom of this gif:
<img src="http://z.about.com/d/autorepair/1/0/_/I/93033214.gif">
The individual wires' insulation have been rubbed through. I need to re-insulate each wire, but does that mean I have to cut them, and splice together? There isn't much wire left between the worn-through section, and the connector. Are the connectors available individually?
Is there any sort of special High-temp Heat shrink tubing I should use? If such a thing exists.
one of those tiny screwdriver kits (jeweler's kit) to pop the pins out, I'm sure a paper clip would work though Just be careful not to deform the lips on the pins.
bertrenolds
Audi allroad
02-09-2016 11:20 AM
aluminumpork
09-25-2006 02:03 PM
MHA4
04-08-2003 06:19 AM
