How common is it for an AMS kevlar TBB to pop off?
#11
So, I put it back on, and really tightened the screws (clamps). I check it every month, and the thing has not budged.
Hairspray is a definite, if not permanent fix.
Good luck!
Good luck!
#12
outside of the pipe with aquanet or another good holding can type fine mist hair spray. put the hose on right away. wait about 5 minutes then tighten the clamp down. now you dont have to do it as tight and riish damaging the rubber
#17
Our Achtuning TBB is an easy install, looks like OEM rubber boot but is actually reinforced silicone, still allows the boost sensor bracket to be fitted and the engine cover goes on no problem, plus it comes with the clamps.
<a href="http://shop.achtuning.com/index.asp?PageAction=VIEWPROD&ProdID=543"><Img src="http://shop.achtuning.com/ProductImages/images/product_images_achtuning/Achtuning_TBB_V2.jpg"></a>
<a href="http://shop.achtuning.com/index.asp?PageAction=VIEWPROD&ProdID=543"><Img src="http://shop.achtuning.com/ProductImages/images/product_images_achtuning/Achtuning_TBB_V2_A.jpg"></a><ul><li><a href="http://shop.achtuning.com">http://shop.achtuning.com</a</li></ul>
Yeehaaa!!!
16
12-19-2002 11:20 AM
S4MadMan
15
10-30-2001 08:22 PM
