how could ramair lead to lower airflow readings?...
Old 08-24-2004, 12:01 AM
Junior Member
back2black's Avatar
Default how could ramair lead to lower airflow readings?...
I see posts of the stock panel filter getting higher g/s readings than with a cone filter. Why is this?
I think I may be seeing a similar issue when i would run my ramair. I saw a loss of flow over the evo intake, but I know the air was colder and freer flowing.
I would like to know what has to be done to get proper readings.
Old 08-24-2004, 12:10 AM
Elder Member
No More B5 S4's Avatar
Default A properly set-up and installed RAM Air Intake will out perform the others. Maybe something...
...is not quite right with your set-up or not optimized.
Old 08-24-2004, 12:48 AM
Funkweasel's Avatar
Default Or it could be related to a huge ridiculous step
in his maf housing? ;-)
Old 08-24-2004, 01:06 AM
VerrÜckt's Avatar
It could be inducing turbulence which could skew readings.
Old 08-24-2004, 01:58 AM
Junior Member
back2black's Avatar
Default Well I use a tube that matches up evenly to the maf...
I used a 3.25" tube. with a large itg filter. The path to the maf is very direct. there is about a 8" long straight section before entry to the housing.
shouldnt this long path make airflow more accurate?
Old 08-24-2004, 01:59 AM
Junior Member
back2black's Avatar
Default i dont like that step
in the maf housing : )
Old 08-24-2004, 06:04 AM
Member
SLPR S4's Avatar
Default When I tested my S-flo is was logging at 280 gps. Too bad it didn't ...
add ANY POWER. The high numbers are caused by turbulence. The FATS test showed no improvement in power.
That is all.
thewatcher101
05-21-2007 04:46 AM
Mark P
13
04-05-2006 05:12 AM
AddictedA4
06-05-2003 05:09 AM
bigalk (back in UK)
12v V6 Discussion
14
04-02-2003 07:45 PM
Agent Orange
12
06-07-2002 06:08 AM
Quick Reply: how could ramair lead to lower airflow readings?...
