How to differentiate between loose steering rack and failing control arms/TRE's...
when the car is on lift and I try moving the wheels with my hands? In other words, what to look for?
Symptoms - I get an audible "thunk" when turning the car into a parking lot. Sometimes I can feel it in the steering wheel and through the chassis. Doesn't happen all of the time. Seems more pronounced with more aggressive weight shifts. This would suggest a loose steering rack, right (can't those bolts come loose on that thing behind the battery?).
I do also get some rattling over potholes...which might suggest control arms or tie-rod ends. Trying to find an easy way to differentiate. I've not been confident with my visual appraisal of the control arm movement. THey seem pretty solid and no torn boots.
When my local shop said it looks like a needed a new one while replacing another CV boot, I decided to do it since the tranny/engine were coming out.
Insist on a new one if you do it...I'd also find a shop that would let you shop around for the part and have a low $hop rate.
likely the bolt, if it moves side to side, its a bad TRE... thats what i was told...
no.radar
Audi allroad
35
11-17-2007 06:24 AM
eigenvector
16
02-25-2007 06:05 PM
aspire a4
10-05-2001 07:18 AM
