How do I check tranny fluid level?
I don't want to change the fluid, I just need to check the level, and make sure I am checking the right one. I have been experiencing grinding into second and had read once before on here to make sure the fluid level was up.
If anyone can help, it would be greatly appreciated!
you still want to check you have to remove the screw from the fill hole. Spec says fluid should be approx 1/4 inch below fill hole.
but I hope your wrong for my sake. The car only has 14,000 miles on it. I used to have an '86 GTi, that had a slow tranny leak, and it would do the same thing....but when i filled it it fixed it till it ran down again.
At any rate I appreciate the info, and it sounds like I will have to dig deeper for a solution.
but there is very big difference
from the old trannys and a 6 speed
s4
but still hope it works for you
to check the level there is a plug
on the driver's side by the axle flange
(17 mm allen) the level must be 10mm
below the opening with the car sitting
in a level surface
good luck
s4
in a level surface
good luck
germantoy
Audi Original "S" Cars
10-16-2003 05:06 PM
