how do i hook up infinity basslink
how do i hook up an infinity basslink in my 2000 s4 b5 that has the bose system? is there a diy out there? I have searched but really cant find anything definative- thanks
and by tapping into rear deck drivers are you meaning just run wires off the 6.5 speakers that are in the deck to the line in of the infinity basslink?
i found this diagram for the basslink- so can i just splice into any speaker of do i have to splice all 4 speakers? and is there any advantage to splicing a rca from the factory bose amp to this basslink or will splicing from speaker be just as fine? thanks
Yeah, the sound quailty might drop a bit by doing it this way. But, the bost amp does some built in signal processing so tapping off the 5 wire low level signal comming from the factory deck usually has poor results anyway.
But if you really want to, the amp is located in the drivers side of the trunk compartment behind the liner. There is a turn on wire, 12V when radio is on, and a 5 wire low level signal. 4 wires are the signal, Front Left, Right, Rear Left, Right, with a common signal ground.
You wouldn't have to tap into all 4 for a line level install, but you could. Since the amp is located right there, you could tap into 4 of the 6 speaker signals. But most of the bass is directed to the 2 rear deck drivers. Then probabaly the rear door speakers. IIRC the fronts are 3.5" or 4.25", the rear door speakers are 5.25" and the rear deck is 6.5".
I ran mine into my ECU box. Just make sure you seal it in some way/shape/form. Under the ECU box there should be a nice big hole to run though. Just make sure the cord doesn't rub up on the steering column U-joint and short out.
can i go around the ecu? I would rather not open it up and risk water getting in there
There are alot of places that could work fine. It only needs a 25A fuse. There might be a spare location in the fuse box that could accomidate that. Not sure.
If your using the line(speaker) inputs. You don't need the remote wire. According to the manual for the Basslink.
