How do I remove the lower ball joint on the front upright/spindle to control arm?
#23
AudiWorld Expert
Actually, now that I think of it, we didn't have to remove that to swap suspension - at least I don't think so.
Knock-on-wood, I hope the passenger side is as easy!
#26
I just used a similar device on my Toyota Sienna, and a 650 ft-lb (the strongest Ingersol-Rand 1/2 inch) impact wrench could barely handle it.
#27
<center><img src="http://gallery.rennlist.com/albums/album228/AudiS4_3131a.sized.jpg"></center><p>
Much less of a problem with the cast iron uprights than the aluminium ones.
Worse case, if you cannot get them off, you remove the upright complete with the control link and then cut the control link away from the ball joint (destroying it) and finally use a press to pop the ball joint out of the upright.
Stephen
Stephen
#30
AudiWorld Expert
<center><img src="http://www.audisscott.com/hubshark/CIMG0102.jpg"></center><p>
However, I decided to just go at it with the breaker bar and 3' extension. The hub shark was bending with some serious pressure on it, so I dedided to stop there, and just press all 4 out. You can see what we went through last time at the link below:<ul><li><a href="https://forums.audiworld.com/a4/msgs/2282516.phtml">https://forums.audiworld.com/a4/msgs/2282516.phtml</a</li></ul>
svetlin_borisov@yahoo.com
12-16-2017 02:35 PM
djordan
07-06-2007 06:27 PM
yooper
04-12-2007 10:28 AM
Avants
11-20-2005 09:50 AM
KaMaKaZieP -ALUMIN8-
04-21-2004 05:25 AM
