How do I take the window switches and lock buttons out of the plastic door pull inserts?
Tried today FOREVER and can't figure it out. Broke stuff.... sweat alot.... swore alot.... and still got nothin. Any ideas? Do the buttons even come out?
cant remember if there is one or two screws in the actual door handle (not the door pull but the oh **** handle), remove them, then it pops out when you press the clip towards the top (up near the mirror switch)and then it should slide right out. Then the window switches should just pop up. Put a cloth over the switch and push downwards. Now for the lock button on the drivers door pull has a red screw in the middle on the backside. Disconnect the tweeter wiring and the actual lock wiring. remove the door pull assembly and place it face down on a cloth and with a flathead you can remove the lock button. This may sound complicated but it really isnt. Should take no more then 10-15 minutes. Hope this is what you were asking about if not then my bad.
Good luck man.
If you do break anything let me know I have spare parts if you need them.
Good luck man.
K2audi
Audi allroad
10
09-29-2007 05:35 PM
Audi_2000_1.8t
10-16-2001 02:40 PM
DFess
Misc. Models Discussion
11-01-2000 06:21 AM
