How do I turn my VAG data into a graph? What rows and columns do I use? Thanks.
Tuesday 30 July 2002 23:24:03
8D0 907 551 M 2.7l V6/5VT G 0002
Group A: '115 Group B: '011 Group C: '003
Engine speed Engine load Spec'd Boost Actual Boost Engine speed Coolant temp Intake
air temp Ignition time Engine speed Mass air flow Throttle angle Ign timing
TIME 0-20% 990-1800 mbar <=1800 mbar TIME -50.2 TIME g/s 0-5deg=closed deg
MARKER STAMP /min % mbar mbar STAMP /min °C °C ° STAMP /min g/s % °
0.46 5320 167.7 2070 2110 0.92 5440 91 61 0.8 0.01 5160 256.92 100 -1.5
1.87 5720 158.6 1950 2040 2.34 5840 91 66 5.3 1.39 5600 262.64 100 1.5
3.23 4680 145.1 2120 1890 3.67 4760 91 68 -4.5 2.8 5120 62.58 24.7 37.5
4.55 4880 169.2 2080 2110 4.98 5000 92 69 0.8 4.1 4840 245.39 100 -3.8
5.88 5120 164.7 2030 2060 6.33 5200 92 72 1.5 5.43 5080 240.97 100 1.5
7.26 5360 159.4 1990 2030 7.71 5440 93 74 0.8 6.79 5280 243.92 100 1.5
8.65 5560 156.4 1940 1990 9.12 5640 93 74 5.3 8.18 5520 254 100 3
10.07 5680 20.3 1000 1230 10.54 5640 93 72 21 9.61 5640 148.19 23.9 14.3
11.48 5520 9.8 1000 1070 11.95 5480 93 74 8.3 11.01 5560 16.03 6.3 9
21.13 5320 170.7 2090 2100 21.57 5400 93 59 0 22.04 5480 261.67 100 0.8
22.51 5560 163.2 2020 2040 22.99 5560 93 62 17.3 23.44 5520 23.83 8.6 42.8
I use Time as my X-axis, requested/actual boost for first Y-axis and RPM as the second Y-axis.
For db 003, I graph MAF data with RPM as the X-axis and MAF value as they Y-axis. Don't know how you would graph coolant temp though.
01northernS4
14
11-20-2006 08:30 AM
Mtouring_Tuff*typing
12-03-2005 05:13 PM
Kapoosh1
14
09-23-2005 02:50 PM
