How do you remove the passenger side door panel?
the interior door handle is loose..I figure there must be some way to tighten it up from the inside. Searched the archives...nothing. TIA for the info.
since we swapped his door panels for mine the other night.
If I recall, there are 5 screws total on the front doors, 4 on the rear doors.
You can get to 3 easily from the outer edge of the door....just a standard philips screw driver.
The others are under the plastic interior liner of the handle. Pry this piece off with your hands, pulling downward. Once removed you'll see 2 additional screws (1 if you're working on the rear door). Unscrew these, then grab the door handle and pull up...the whole panel will come right off.
Bisqueth
03-31-2009 02:24 PM
tree580
09-30-2007 07:20 PM
Tim NYC (E28 M5)
11-09-2001 05:53 AM
jawsplace
02-21-2001 09:26 AM
