How do you remove the rear deck lid to get the third break light
housing out. It is late and I been tinting all day long. So if you are going to post STFA or RTFM don't bother. All I want is a answer or a link to where the answer is. Thank you
then remove the 3 plastic covers on the hooks by lifting the front side with a flat head screw driver. Remove the 3 bolts, lift the front to remove the small clips and then slide the deck cover off.
pop off the plastic covers, then remove the 13mm bolts. Then with the seats folded down, push up on the rear deck, then pull it towards you. Make sure you unplug the BRAKE light from underneath in the trunk before removing the deck.
S4incter
01-07-2006 06:33 AM
TwinTurboTerror
03-06-2005 02:31 PM
laxnbenny
11-12-2002 01:30 PM
John Audi
02-03-2001 10:58 PM
