how does the 235/40/18 tires fit on the S4. ..? perfect ...or...?
some sales rep kept pushing me for the 225/40/18, and told me that the 225 is better than the 235.
is that true? or......?
putting that on the 18" Kahn Rss.
A 235/40 is enough bumpier than stock that I plan to go back to a 225/45 for my next set of road tires.
RR
RR
Right now I have 225/40/18 on 18x8.5ET32 rims, stock suspension. It looks like there would be plenty of room for a wider tire. here are some calculations:
225/45/17 (Stock)
H=25", W=8.9"
225/40/18 (the most popular size on AW)
H=25.1", W=8.9"
Actually w/ Pilot Sports its more like 25.2". and the same width as stock so it will look strechted out on a 8.5" wide rim, although I have been told that these pilot sports will work on a 9" rim.
235/40/18
H=25.4", W=9.3"
I wouldn't go this way. Too tall, impacts your gear ratios/speedo, and you will probably have to roll fenders if you lower.
245/35/18
H=24.8", W=9.6"
This will probably work pretty well, but a little shorter in height.
255/35/18
H=25", W=10"
This would actually be my preference. It doesn't look to me like it would rub w/ stock suspension. and at least one person on this board said it wont. But others said it might. I cant get a definitive answer on this. But I think it would be the best. Same Height as stock and 1 inch wider.
But to answer your question, 235/40/18 is not the perfect option.
-Alex
225/45/17 (Stock)
H=25", W=8.9"
H=25.1", W=8.9"
235/40/18
H=25.4", W=9.3"
245/35/18
H=24.8", W=9.6"
255/35/18
H=25", W=10"
-Alex
Don't remember exactly the contents of your email (i'm at school right now), but yes, your car with stock ride height will have absolutely no problems with 245/35 18. AFAIK, Pirelli P-Zeros and some other no name brand make the 245/35 for street radials.
I'm lowered >1.5" and it only rubs on high speed dips. I may raise the car a bit (I have H&R Coilovers), but I think I'm just going to roll the fenders. That should easily take care of it since when it does rub, it's never severe. I would prefer a 35mm offset, but don't worry, they'll wrap around our RXII's quite nicely. Even with a conservative drop, you'll still be fine. Not sure about the 255/35's however. I'm even willing to speculate that with a 255/35 18 and stock ride height, it will not rub (even with 3 passengers on hard cornering). Do me a favor, put the 255's on, drop your car and let me know how it goes![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
Rami
Rami
