How much horsepower for a tip?
#21
I'm only APR stage I, but after my 72K timing belt change (I know, what does that have to do with the tranny), shifting between 1-2 and 2-3 with alot of torque going to the tranny causing it to almost shutter either between the shifts, or even sometimes after just letting up off the gas a bit. I'm NOT tipchipped. This stuff every happen to you before going L10?
#22
Hmm no I didnt have that problem, but there is something called converter shutter. Have you ever checked your fluid level? When you say shutter do you mean you feel an indecisive shift on the trannys part? I believe there is an alignment for the tip *trying to remember* maybe someone will chime in ..
#23
Dealer checked the level, and said it was just fine. Expect that in tip mode... its not trying to shift, but it feels like the converter (excuse my ignorance to what it really may be) almost bounces up and down before grabbing hold again. No issues whatsoever in stock mode, but then the torque is much less.
And all of this after my timing belt change...
Are you thinking of the tip adaption thru VAG maybe? This is really driving me crazy, and ruining my fun!
#26
be taking a crap
How many miles does it have? With the addition of a chip the transmission is subjected to more heat which does kill any automatic transmission you should check into adding an additional cooler to yours. I have pix so does VRLIFE he has a writeup on how to install this. Just as a last attempt at solving the problem try the VAG with the adjustment. *shrug*
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
rakta *chchchanges
17
05-05-2008 12:05 PM
drgolfnut
05-24-2005 10:04 AM
MZimm
10-24-2004 10:34 PM
Bryce
09-08-2002 11:45 AM
