How much HP will the GIAC race fuel mode increase?
how much hp will it increase from the standard pump GIAC? Is it worth it? How much would it cost to add it on to my ECU?
DO I NEED THE RACE FUEL PROGRAM TO USE RACE FUEL OR CAN I JUST USE RACE FUEL WITH THE STANDARD PUMP GIAC PROGRAM?
And how much delicious timing and therefore 'HP' depends on your setup. This creates two variables, so I can't answer that one for you...unless you'd prefer the answer as a DIF-EQ....
Race profile might give you instant adaptation - but the pump profile will still add in timing and end up getting you to pretty much the same place.
Meaning there is only so much timing you can gain on the pump file at a given amount of octane points higher than what that file calls for. I'd be interested to know if this line of thinking is correct or not....I mean your results seem to indicate otherwise.
Marin S4
21
12-09-2004 04:05 PM
addìct
14
04-15-2003 04:13 AM
