How Much in Labor only to replace Drv side Turbo??
Old 07-31-2004, 05:44 PM
Junior Member
Rokšped's Avatar
Old 07-31-2004, 05:46 PM
VandyS4's Avatar
Not much less than both, I'd imagine. Engine needs to come out.
Old 07-31-2004, 05:54 PM
VerrÜckt's Avatar
YOU MUST REPLACE BOTH.
Old 07-31-2004, 06:05 PM
Member
C. O. Guy2's Avatar
do not go there....2 by 2 just like noah!
Old 07-31-2004, 06:10 PM
XCCESS's Avatar
do K04 while you at it,, alot cheaper too
Old 07-31-2004, 06:47 PM
Junior Member
fl2.7T's Avatar
Default Never read anything as WHY? The KO3 is the same for the 2.7 & 1.8, correct? Is there some kind
selection/matching process (like vacuum tubes), and if so, what does it entail?
Old 07-31-2004, 06:49 PM
Senior Member
Skydive@AI's Avatar
Default They aren't the same...
...and because if one is gone, the other may go as well. Do you want to pay twice?
Old 07-31-2004, 07:01 PM
VerrÜckt's Avatar
Not the same.
Old 07-31-2004, 07:02 PM
VerrÜckt's Avatar
Yep. Having one go puts an enormous amount of stress on the other.
Old 07-31-2004, 07:34 PM
Member
Ochlockonee's Avatar
Default If the shaft broke on the driver's side turbo, it may be because you have compressor or turbine
strike on the passenger side. If for any reason one turbo isn't spinning as fast or producing enough boost, the other gets overspeeded to make up the work. I did the same thing and replaced my driver's side turbo with a used unit from e-bay only to grenade that one soon after. After I decided to pull the motor and replace them both I found out the passenger's side had compressor strike.
Quick Reply: How Much in Labor only to replace Drv side Turbo??
