how much of a PITA is to change the cam seal in the back of the motor driver side?
it was just changed and the thing it was leaking from the get go.. i thought it was the valve cover at first ;(
timing belt.
I had an Audi tech friend come over because I didn't have the little tool to push down the cam tensioner.
The other thing you need to be careful of is folding over the edge of the little rubber seal - I guess it's pretty easy to do when installing if you're not careful.
I'm not sure where you'd get the tool but I think you need to use it.
The part is ~$5 IIRC.
on the front i drill a little hole in the seal and pull it out hooking it by that.
Might be worth looking into getting one.
It's an Audi tool so it should only cost a billion dollars.
<ul><li><a href="http://www.zdmak.com/wbstore/main.asp?action=PROD&PROD=VW3366&CTMP=1">V W 3366 tool</a></li></ul>
Maybe this one then?<ul><li><a href="http://www.zdmak.com/wbstore/main.asp?action=PROD&PROD=VW3241&CTMP=1">V W3241</a></li></ul>
devinsixtyseven
11
12-06-2012 06:40 PM
divil
11-05-2011 08:13 AM
johnkk
32
01-14-2008 11:58 AM
