How often should springs be changed?
I have the H&R Sports springs and the Bistein Shocks (grooved). Been on for what will be 2 years next spring. I've heard that some springs begin to sag after about 3 years of use...any suggestions?
there is a noticeable sag or some kind or noticeable difference in compression (ie too soft etc). Also, IMO if you are feeling its a bit floatier then before its likely that the shocks are wearing out rathar then springs losing any spring rate (should be relativel fixed) or anythint like that.
H&R springs are warrantied lifetime against sag though i hear you need to "prove" it to them(if it is sagging) to get any kind of help.
that's a long time...
Springs will "sag" over time. Over time, I mean 50 years. I have a 33 year old Alfa Romeo and it's a known fact in the 'historic' car world that the rear springs "go bad" after a while.
The H&R springs should last a long, long time.
springs were WAY underdesigned for the loads they were going to see. Ever see one of those things; they have about 2mm of ground clearance in the rear (bumper just about draggin' on the ground) and it is every stinkin' one of them. I'm always amazed whenever I see one (I work in an urban area, so they are a lot more common than one would normally expect...). Not Audi related, but I couldn't help but think of that after seeing your post. =)
Yes, you're right and that's the point. What is the correct material property and hardness to ensure that a coil spring never "sags"?
I can't think of a design or technical specification that ensures it.
You darn tootin' they're expensive to fix! I will NEVER get an air suspension system ever again. It's not a question of if they will fail; its when will they fail and will you get stranded somewhere.
they all fail eventually (i cringe to think what allroad people will do if theirs fail as Audi = even more $$$)...luckiy for the GM folk they aren't stranded, just dumped in the back with ****ty ride. aftermarket companies do sell traditional spring/strut suspensions to replace the air suspensions though (which i did't know til i googled just now)...
