How to remove D-pillar airbag cover and wood trim around cupholder/foglight switches? Ashtray?
How do I remove this without setting it off? I want to string an antenna wire back there. I know there is an existing channel back there already.
Also, the piece of wood around the foglight switches/cupholder. Do you just pull it straight out? It was a real bitch to get a grasp on...is there a trick to it?
Lastly, how do you remove the ashtray?
Pop off the little plastic rectangle that says 'airbag' on it. Under that you will find some Torx screws. Remove them and carefully yank on the piece. It will pop off. Be careful not to bend it because creases will show.
first.octopus
08-08-2015 09:34 AM
Rodney
09-13-1999 04:42 AM
