How would a bad N75 valve affect requested boost?
#21
I requested spikes then tapers to 3-4 psi lower than my actual. Now of course with the TCD the actual boost is stuck at 1 bar. But what would make my requested go below 1 bar? This is for homebrew stage 3 tip.
#24
If so, that somebody was me.
I told him that if the car is requesting 2300 millibar and the actual is not there, that is a hardware issue and not software.
However, this data is different than what Meraj told me. He said the requested was much higher. He saw 2400 millibar at some points.
His boost gauge was not matching up with his logging. I said that was a hardware issue and not the software.
Possible issues are boost leak, or bad N75 valve.
#25
BTW, I got those injectors from VAST and once I get things swapped out I'll send you some logs. I should probably do some logs that morning before the swap too?
#26
It's not that his car isn't making requested boost, but that request boost is low compared to other stage 3 cars which is resulting in a slow car...relatively speaking.
#28
How come you did not just come right out and say that Meraj was speaking to Mike at AWE and this is what he told him?
You made the post, why leave out all the details?
#29
going to log 115 and take a look at my requested and actual boost.
mike -- my car seems like its kinda of weak. dunno why, but it does. just looking to find out what could be wrong with it.
my VDO boost gauge sees a spike of around 20 PSI, then it dies down to 15 or 16 PSI till redline.
#30
I didn't know if you'd be around to address it or not. I simply wanted to know if it were a possible explanation even though I can't personally make the connection. I never was going to mention you.
