Hub Rings and H&R 5mm Spacers Causing Vibrations...
I had to get some 5mm H&R Wheel spacers for my Ronal R41's, which already have hub rings. So now the hub rings don't fit and lock on to the hub correctly due to the spacers and are causing vibration at high speeds.
Is there a solution for this? Are there hub rings that are shallower that will catch easier or something else that will fix this problem? Any info would be great.
AudiWorld Expert
hubcentric spacers.
<center><img src="http://www.bmwtips.com/tipsntricks/Wheel%20Spacer%20Notes/Image1.gif"></center><p>
although im not certain they make mismatch sets... if you contact ccw they may be able to make a custom set for you.<ul><li><a href="http://www.bmwtips.com/tipsntricks/Wheel%20Spacer%20Notes/Image1.gif">http://www.bmwtips.com/tipsntricks/Wheel%20Spacer%20Notes/Image1.gif</a</li></ul>
JoeyVee
05-30-2007 02:09 PM
lkeneston
05-25-2006 02:10 PM
Dutch8griffin
Audi allroad
06-30-2003 06:54 PM
