I already AWE stage 3, with TCD cause damage?
#11
All that, yet I run XR with TCD and get negative deviation code + limp due to high requested spike.
#12
I used it without any problems at all.
I'm using the same one now on KO4s with MBC only and am getting negative devaition codes with SEL set at 100%. I never get limp mode with XR, TCD and MBC only, is that wierd?
#13
Otherwsie, that code would induce limpness.
What I'm getting at is that GIAC K04 software requested more boost than XR. In that case, it would make sense that you'd get the same code and same limpness with that software. However, if you ran MBC only you'd just get the code.
Wow, I just explained it to myself. Go figure. ;p
So then with K04 GIAC code, you got the negative deviation code on a regular basis?
Maybe the problem with FatFree is he runs MBC in parallel?
#15
Or, I guess it could be because my N75 is out of the loop.
I NEVER got a negative deviation code when running MBC only, TCD and MBC with AWE KO4 code - totally odd, huh?
ktnguyen
17
08-21-2007 10:52 AM
GoodMatt
10
03-05-2007 08:15 AM
elijahallen
10-17-2006 07:55 PM
bradsky77
12-08-2002 03:27 PM
