I can get GT's and manifolds for $4000. How much would a custom tune cost?
#11
Try reading my posts. Apparently, the GT manifolds are available to purchase by themselves, so I was told by a local tuner.
#12
i have no idea if this guy does or does not have any info on Niko's car, but if you have the motor on a bench, and the turbos, you can tell a very good manifold maker the demensions of your body and he will make you exhaust manifolds.... you don't have to copy others components, but rather be skilled in the header/manifold feild.
#13
Point is, if this is as easy as people around here seem to think it is...why aren't there at least five different GT based kits to choose from on the open market? Heck, the S4 has been out since '98.
There you have it. It takes money, knowledge, skill, desire, and commitment to make a GT based system. That's why they aren't falling from trees.
#14
If he sourced some tial wastegates and had the same guy that made his mani's make his dp's, I don't think he would have a problem as long as he went somewhere where they knew how to tune...
I don't know who S4KTS is, but I like to hear some new ideas, and it just seems that people shoot them down a lot.
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
#16
that are a lot more extensive. Why would they be no good? If he has a reputable manifold/header maker and gets them coated, there is no reason for them to be inferior to another manifold, shoot if he sourced the top notch welder/craftsman, they could even be better?
#18
wastegates mounted. The GT's internal wastegates would then need to be welded shut. Small stuff but it adds up and if not done right will cause major problems. Custom tuning can get VERY expensive. Not many people do it and since GT's are relatively new and unexplored it wont be as simple and quick as a K04 based turbo tune.
#19
like you can count the number of cars that had GTs on one hand.
I'm not accusing you of anything, but the seller might be suspect
