I don't really know VAG speak, so can someone please translate this?
This are the errors I got from my auto failure that I posted yesterday.....
VAG-COM Version: Release 303.1
Control Module Part Number: 8D0 907 551 L
Component and/or Version: 2.7l V6/5VT G 0001
Software Coding: 06751
Work Shop Code: WSC 06325
4 Faults Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-00 - -
18320 - Pressure Sensor for Brake Boost (G294): Short to Plus
P1912 - 35-00 - -
17837 - Circuit for Brake Vacuum Pump: Open Circuit
P1429 - 35-00 - -
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-00 - -
Control Module Part Number: 8D0 927 156 BS
Component and/or Version: AG5 01V 2.7l5VT USA 3132
Software Coding: 00022
1 Faults Found:
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-10 - - - Intermittent
__________________________________________________ ______
4 Faults Found:
P1429 - 35-10 - - - Intermittent
P1912 - 35-00 - -
P1650 - 35-00 - -
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-10 - - - Intermittent
1 Faults Found:
4 Faults Found:
P1650 - 35-00 - -
P1912 - 35-00 - -
P1429 - 35-00 - -
P0118 - 35-00 - -
1 Faults Found:
4 Faults Found:
P1912 - 35-00 - -
P1650 - 35-00 - -
1 Faults Found:
err...in my uniformaed opinion....that don't look good
expecially the brake sensor one....
sounds like you need some dealer help or someone else knowledgeable with these cars as a whole...those are some not commonly seen faults if my memeory serves me.
the missing data codes are usually when you key off while in a cluster vagging. i would delete them
and not worry.
Not sure about the brake codes.
On the temp sensor - has your car been running strangely lately?
Strangely would be correct.....
I'm not worried about the brake codes...
The car did DIE on me the other day...EPC light and all. I'm thinking the 02 sensors and TCM are dead....anybody else have any thoughts on this?
o2 sensors?? there are no codes on there that suggest o2 sensors. the coolant temp sensor causes
engines to run badly but usually just a loss of power - not car.
you're a tip, eh? sounds like it could be the tcm then.
I wouldn't just haphazardly replace the TCM. There's got to be a way to test it in Bentley -
although you might need more than a vag. the coolant temp sensor is cheap to replace <$6 IIRC. I would replace it to eliminate the possiblity since it's so cheap.
Have the TCM tested before replacement. Might be time to go tip-chip?
That's the only chip that is left in there....
If my car wasn't paid off already, I'd trade it in for something else. I just hate the idea of starting car payments all over again. Especially now that I have a mortgage.
Damn, when things go bad on these cars....the SHTF big time!!!!!
