I feel dumb for asking this.... Electrical relay BT? EDL defeat discussion inside.
Ok so i need to have a relay that works in the opposite fashion of a standard relay. Basically an interupt. I know these exist but I have no idea what the name is to call around and find one.
I am going to hook two up to the lines on the underside of the ABS control module. i am tired of the standard edl defeat causing problems (ECM codes, no cruise control, eratic EDL pulsing, over heating of control module). then i could just flip my switch to supply 12v, it would interupt those lines and it would be just like when its unplugged. i dont want to depend on a relay being on to keep the lines connected under normal driving that way if something fails or a fuse pops the car wont loose abs on the road.
TIA
TIA
AudiWorld Expert
just get a 5-pin standard 30A/40A automotve relay. pin87A is N/C pin87 is N/O
Sounds like you want to connect to 30 and 87A. Those are connected (N/C = Normally Closed) when at rest, and then when you apply power and ground to 85&86, then the relay switchs to now connect 30 to 87 (instead of to 87A). Thus it makes a disconnection between 30 and 87A. Sounds like that's what you want.
Here's one in use in my headlights:
<img src="http://ctny.audiworld.com/mark/s4/euros/dsc01783.jpg">
This is one of my favorite sites for Relays:<ul><li><a href="http://www.the12volt.com/relays/relays.asp">http://www.the12volt.com/relays/relays.asp</a</li></ul>
