I found my Stumbling Idle Misfire.. my intake manifold hole is stripped.. help please
Old 02-15-2007, 05:53 PM
  #11
The R's Avatar
Yea, I'm around. Just lurking in the background most of the time.
Old 02-15-2007, 05:56 PM
  #12
silva's Avatar
Default You can drill it out and insert a Helicoil in there...
Basically, a helicoil (or threaded insert) replaces the stripped threads with new ones. Next time, you should definately use a torque wrench.
Old 02-15-2007, 06:02 PM
  #13
eigenvector's Avatar
thank you!!!! is it a 5mm ?
Old 02-15-2007, 06:17 PM
  #14
silva's Avatar
Not sure which bolt it is, but it should be a 6mm thread.
Old 02-15-2007, 06:23 PM
  #15
thank u so much im going to go to napa first thing in the morning.. ur a life saver thx man
Old 02-16-2007, 06:15 AM
  #16
lemieux@curbside's Avatar
Default :/ next time put a real pic there of the eventual problem ... not a f-in lure
i hate that.
jack@s !
yes you can tap and die that to the next size bigger .. take the stock bolt with you and go to a sears hardware store and find the next size bigger (even if it's longer you can just cut it to the length u need) . to tap and die it corrctly i'd pull the mani out and do it right (DO NOT RUSH) , as you drill keep the shop-vac on so it will suck up all the metal shavings so they don't go in the motor ( u can also tape up well the holes too). all this should be easy .
Old 02-16-2007, 09:05 AM
  #17
Gator Al (Al)'s Avatar
Default It will also be stronger than the aluminum ever was.
Don't ask me how I know... <looks both ways>
Old 07-08-2009, 07:20 PM
  #18
qfjsy's Avatar
Won't hurt to ask. He's damn near done everything on that Avant
Old 07-12-2009, 01:23 PM
  #19
abduln's Avatar
It's the same solution as for a sparkplug thread repair; you can use a Helicoil kit your manifold bolts.
I just did my auxiliary pump, so I empathize with having to take it all apart again, at least it's easier this time... unless you reinstalled using factory crimp-on hoseclamps.
Good luck.
Vegas34
03-02-2010 05:34 AM
VOoDOoGTX
Audi 100 / A6 (C4 Platform)
02-24-2007 07:06 PM
SunDevilA4
Pacific Northwest Discussion
03-14-2005 12:44 PM
audijim113
11-22-2004 07:29 PM
carlosii
08-30-2004 10:45 AM
Quick Reply: I found my Stumbling Idle Misfire.. my intake manifold hole is stripped.. help please
