I just can_not figure this **** out!
stock 01 S4, tip, 102k.
I'm having a misfire that is just really hard to shake and I've gone through quite a bit already:
in chrono order:
-(codes) misfire cyl 6 + random cyl misfire
round 1
-popped of cyl 6 ignition coil, coil was clearly shorting out to the head, the side was melted.
-replaced all 6 coils, and all 6 plugs (ngk prf6q plugs)
-also replaced all 6 spark plug connectors
------misfire still present
round 2
-swapped out the pos ingition amp, misfire stayed with cyl 6. (same cyl 6 / random cyl misfire code).
-took a look at all the ignition coil connectors (pulled back connector boot) to make sure no wires had been compromised.
-swapped out cyl 4 fuel injector with cyl 6 injector.
------misfire still in cyl 6, lots of misfire
counts through VAG only in 6, a few in cyl 3.
round 3
-removed the ecu cover and took the ecu out, took it apart and looked at the circuit board, didn't see anything fried, everything looked ok.
-also split the casing of the wiring that holds the wires for the injectors and coils for bank 2 (cyl 4,5,6) didn't see any indication of arcing or split wires.
-did a compression test on cyl 6 only with plug still in 5, tested good @ 160psi
Any thoughts for round 4?? I'm pretty well almost TKO'd right now.
in chrono order:
round 1
round 2
round 3
how about checking whatever sensor the car is detecting the misfires with?
maybe a valve is ****ed somehow?
fu<k i'm soo not looking forward to working until 930p @ my job then going to my garage and being up late working on this thing again...
in my experience it usually turns out to be the most annoying simple thing that causes the issue - i'll take a look at that cable. i'm not familiar with location? can you help? have you had an issue with yours?
