I just finished installing the EDL defeat mod, but decided to install a switch
#21
if you want to wrap your intake pipes(if you haven't already). Bought two packs and used the first and maybe 2' of the other...
Thanks for the offer though!
#22
Shiny aluminum line filled with synthetic oil not contacting anything it wasn't designed for (and it was designed to contain conventional oil). Air is a great insulator and the material is a perfect radiation shield.
I *DID* wrap the lower inlet pipes with 1200deg thermal tape though. For $20, why not... and the same can be said for your sheath
#24
And the only thing I seem to ever notice that's different while driving one is the extra button on the dash that needs to be turned to its misnomer of an "off" position.
#25
the thicker stuff with safety wire... as well as Swainteching a set of manis, which I ported/smoothed slightly, along with spacers and ported mani(already done)... will the madness ever end?
#28
If '01+'s had real NAV screens I definitely would've bought one. Since I was buying out of warranty for stage 3, I figured the extra expensive sensors of '01+ ESP would be a liability.
Oh, do you think AVC-R will work with APR software? Do MBC-only even work on apr? I would like to get it wired up soon. thanks
